Hi All,
I'm in the final stretch of the bottom-up rebuild of a 95 850 turbo rebuild. There is a brass fitting inserted in the block, just behind the water pump and above the axle mounting bracket, facing the passenger side firewall. When pouring coolant into the reservoir, it gushes out that fitting (well, duh- stupid me for not noticing that prior). I cannot figure out what hose should be fitted on that fitting. I no unaccounted for hoses or fittings anywhere.
If you go to
http://rides.webshots.com/slideshow/563883893OGxoym
and look at image 40 very closely, you will see it just above the axle mounting bracket.
Help!
Thanks,
John
Help! 850 Rebuilding-Coolant Everywhere
- Year and Model: Many Volvos
- Been thanked: 76 times
Great looking motor build.
Is that not a coolant line for the turbo? I will fire up a windows partition to take a look for sure.
What's up with the orange can of death hanging of the sump?
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
I was wondering the same thing. Although I never heard "Orange can of death" before
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
For most domestic cars it is my gold standard but on a Volvo a Fram oil filter is not a good thing, the check valve sucks and the lifters will clack like crazy on startup. For my part I just order in Mann filters by the case.Orange can of death
I noticed this on my 97 855R last weekend while putting my OBX exhaust on the wagon. Popped next door to the neighbor (Indy Volvo shop) and he said it was the block coolant drain. I would assume you just tighten it up and the leakage will stop. No hose is supposed to be on there..
cya,
Tom
cya,
Tom
jofinneg wrote:Hi All,
If you go to
Help!
Thanks,
John
You have a really nice Strut brace there in pic 30. Also like the inlet manifold is that a stock turbo one or one you've had manufactured ? Can you let me have the company email to both plz hopefully they export to the uk.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
- 23 Replies
- 4597 Views
Last post by MadeInJapan
- 78 Replies
- 12278 Views
Last post by PeteB
- 932 Views
Last post by beigg
- 2512 Views
Last post by midimykeys
- 967 Views
Last post by Vazfx16
