S60 2004 Can not locate fuel filter
I am unable to locate the fuel filter on my volvo. I have read a few things that say it is located next to the fuel tank but I have looked in front of, next to and behind with no luck. I would appreciate any help with this as I am very frustrated! Thanks
rbodor3
- Year and Model: 01 S60 LPT
- Been thanked: 2 times
lift the passengers rear wheel and you'll find it more easily. It's in front of (towards engine) of the rear passenger tire, very close to the outside (door) of the car. It will be covered in asphalt, dirt, etc. but you'll see (2) quick connect style fuel lines connected to it, and (1) iirc 15mm bolt holding the bracket that holds it all in.
01 Volvo S60 2.4T
OEMVolvoParts
- Year and Model: ALL
Post your vin number on here to find out for sure. There is a certain type of fuel pump setup/emissions code where there is no fuel filter you can service. It is built into the pump in the tank.
Cars with emission code " A, T, V, 2, 7, 0 " will have the special pump and filter design. Your emission code is the eighth digit in the vin. Check to make sure this is not your car.
- 2718 Views
Last post by erikv11
- 656 Views
Last post by Ozark Lee
- 8003 Views
- 2122 Views
Last post by peripatetic
- 15 Replies
- 636 Views
Last post by Faust
