V70 T5 2001 strange noise from automatic gearbox
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Jagger
Year and Model: 2005 XC70 T5 295'km
Has thanked: 1 time
Post by Jagger »
Sometimes, when I pull away (from a dead stop), there is a noise coming from the gearbox as if something is engaging, like a knock. I don't know too much of automatic gearboxes, but I think maybe there is oil missing. Does anyone of you have similar problem or experienced this?
Jagger
thornockfamily
Year and Model: 2001 V70 T5
Post by thornockfamily »
MINE TOO!!! IM RIGHT THERE WITH YOU PAL!!! I BOUGHT MY 2001 V70 T5 IN DECEMBER. SINCE THEN I HAVE HAD A COUPLE OF WORRIES ABOUT MY TRANSMISSION, ESPECIALLY HAVING TO REPLACE IT! MY CAR JUST CLICKED OVER 100K, AND FROM READING UP ON MY NEW CAR....I DISCOVERED THAT ITS NOT THE BEST TRANSMISSION IN THE WORLD! PLUS, ITS VERY EXPENSIVE TO FIX IF SOMETHING DOES GO WRONG. SO, WHEN MY CAR STARTED MAKING A VIBRATING NOISE NEAR THE GEAR STICK....I STARTED PAYING ATTENTION. MY CAR STARTED TO RANDOMLY SHIFT HARD FROM REVERSE TO DRIVE. AND WHILE DRIVING IT STARTED TO SHIFT WITH A JOLT THAT YOU COULD FEEL IN YOUR SEAT. IM CONFUSED ON THE TRANSMISSION FLUSH...SOME PEOPLE TELL YOU TO HAVE THEM HOOK IT UP TO THE TRANSMISSION FLUSH MACHINE AND OTHERS SAY THAT ITS THE WORST THING TO DO. SO, IM DEBATING ON WHAT TO DO. BUT EITHER WAY, MACHINE OR HAND DONE, A TRANSMISSION FLUSH OR CHANGE WILL LET YOU KNOW WHATS WRONG. IF YOU HAVE IT DONE AND THE TICKING IS STILL THERE IT MIGHT BE A MORE MAJOR PROBLEM.....OR IT COULD JUST BE A LOOSE BOLT! EITHER WAY, ITS PROBABLY A GOOD IDEA TO FLUSH OUT YOUR TRANNY.!
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
As has been posted here on this forum and others many times before. If it hasn't already been done, take your car to the dealer, have the stop-neutral function in the transmission disabled and be sure it has all of the latest software downloads. Drain and refill the transmission or flush via the transmission cooler line, (pump two quarts out, put two quarts in), not by a flush machine. Use only JWS 3309 spec fluid (dealer, Mobil 1 3309, or Toyota T-IV fluid) and cross your fingers.
Checksix
Year and Model: V70 T5 2001
Been thanked: 2 times
Post by Checksix »
Listen to what Otis44 had to say as he nailed it perfectly. A power flush is just more problems. I've use the cooler line technique with 2 out 2 in technique and it is quite easy. Drain and fill works too, but getting the fill level right is a bit more difficult, but manageable.
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
