The high beam/low beam shifter works only once in a while. It will shift to high beam but returns to low as soon as the arm is released. I suspect the headlight relay to be malfunctioning.
- How do i locate the relay? It does not seem to sit around the others under the instruments and beside the fuses as the rest of the relays.
- Does anyone know how to test and if in need to repair a relay?
- Are there any other places to look for faults?
240, 1993, locate headlight relay
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
It is next to the battery.
The only way to test a relay is by replacing it with a known good one.
You can open the case to see if any solder joints have come apart and re-solder them.
The switch itself may have developed a fault.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
kaerlighedsbamsen
- Year and Model:
Bill you are once again a star! Will return with resuts.
Best of luck!
Ty
Best of luck!
Ty
- 2722 Views
Last post by erikv11
- 656 Views
Last post by Ozark Lee
- 4393 Views
Last post by WA-Boater
- 1001 Views
Last post by ProjectS90
- 11 Replies
- 2824 Views
