S60 2001 nearside drive shaft (uk)
adam180
Year and Model: S60 2001
Post by adam180 »
Hello everyone
Well i have managed to get my struts sorted out, thanks to your help.
But while doing it, some how i managed to pull one of the drive shafts out at the gearbox end.
I put it all back, but when taking the car for a test run it was all fine until i turned right at a roundabout.
The drive shaft pulled out its seating (cage for ballbearing & cage stayed in).
Anyone got any ideas why this happened, the part on the end of the shaft with the clip stayed in place (dont know what this is called), plus i got the tracking done after doing the strut by a local garage.
It was fine for a couple of days?
Thanks in advance for any help.
cheers Adam
rbodor3
Year and Model: 01 S60 LPT
Been thanked: 2 times
Post by rbodor3 »
You probably jerked too hard and removed the boot cover for the drive shaft. if you have only driven a couple of miles, not in the rain and not thru a lot of dust/dirt, you could just replace the boot cover and regrease. But it sounds like you've driven at least 10-20 miles. I wouldn't chance that dirt, rocks, dust, etc. didn't get into the driveshaft.
Bad news - you need to replace the driveshaft. Runs about $150 (www.ipdusa.com)
Good news - it's really easy. Remove the drive shaft bolt from the hub (17mm iirc), remove the clamp holding the driveshaft, pull the driveshaft out, pop the new one in, and reverse.
01 Volvo S60 2.4T
adam180
Post by adam180 »
rbodor3 thanks for your help, i did have trouble getting it back in, and didnt make sure that cage part i talked about was sitting straight, could it be that?
cheers adam
adam180
Post by adam180 »
hello again
does anyone know the name of the type of drive shaft thats used in this car?
Also what is the part of the drive shaft that has 6 bearings a cage and the part on the shaft connected with the clip.
cheers Adam
rbodor3
Post by rbodor3 »
Is this photo the axle you're talking about?
Not sure what you're asking for. Are you getting your drive shaft rebuilt?
01 Volvo S60 2.4T
adam180
Post by adam180 »
That's it what it called at the end the closest end in you image.
cheers Adam
