SRS Reset procedure
wolfspiritky
- Year and Model:
Checked the repair database and found an SRS reset procedure for the 240 posted by Dave (MIJ). Is there one for the 850??
00 S80 T6
97 850R
94 850 GLT-Totaled!
97 850R
94 850 GLT-Totaled!
- Has thanked: 17 times
- Been thanked: 35 times
Depends on which 850, Wolfy...if it's one of the older ones with the modules under the hood, yes...otherwise, dealer or a few different software that are proprietary...
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If you mean for your '97, you can do it with one of these:
http://cgi.ebay.com/Draper-Volvo-Servic ... 23037c673b
It'll reset that pesky "Service Interval Light", too!
Ah...forgot about that- I actually have one of those I use on my '98 S70 but never tried (never had a need) to reset the SRS light on it.
wolfspiritky
- Year and Model:
Hey Dave how you been? I never seem to be on line at the same time with you.
Anyway, the SRS light is on my daughters 95.
Lost compression for no "known" reason in #'s 1 & 4 a few months back. Did a swap but I guess I didn't pull the heater core lines completely out and broke the inlets off the core. I pulled the dash to replace it so (SOOOO much fun by the way
), while I was in there I put in a new evap core as well. Got it all back together and had no power to the cluster, switches or head lights. I found a large red connector that had come loose, you could barely tell. So, I pushed it back together not thinking I had the battery reconnected or that th SRS system might be powered through that plug....guess it was. Now I have a light.
My sons 97R has been a JEWEL! He had a pretty good oil leak so, I had to replace o-rings on the oil lines at the cooler and the seal between the cooler and block/oil pan. $6 and hour and a half of work.
00 S80 T6
97 850R
94 850 GLT-Totaled!
97 850R
94 850 GLT-Totaled!
Wolfy- there are short cuts right... disconnect battery leads...wait 15 mins...touch the wires together (not with battery!)... push down the brake pedal at the same time and you should reset all of your codes but you'll have to drive it a bit if you have to be "ready" as in for emissions as the adaptive reset when you do this too. Good luck- hope you didn't bugger something up behind the dash.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
My SRS light is still on after leaving battery disconnected for a couple of hours. Which wires do you touch together when the negative cable is off? Which ones must NOT be touched together?
JB
JB
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I thought that it's impossible to reset the codes this way.Is this for pre '96 models only?MadeInJapan wrote:Wolfy- there are short cuts right... disconnect battery leads...wait 15 mins...touch the wires together (not with battery!)... push down the brake pedal at the same time and you should reset all of your codes but you'll have to drive it a bit if you have to be "ready" as in for emissions as the adaptive reset when you do this too. Good luck- hope you didn't bugger something up behind the dash.
As far as i "learned" till now...all of the codes remains memorised in the ecu untill reset.Disconnecting battery terminals will only reset fuel trims and check engine light on instrument cluster,but codes remain memorised.
Right?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
confused_al
- Year and Model: 1996 TLA wagon
I just added this to Jim's thread (its from the service menu):
On-Board Diagnostic (OBD) unit performs 2 tests: a start-up
test and a cyclical test. During start-up test, microprocessors
perform complete system diagnosis. Faults will not be recorded until
start-up test has been repeated 1 or 2 more times. Cyclical test is
performed 4 times per second. Faults must be detected during 2
successive measurements before they will be stored. After a fault has
been detected for 10 seconds, it will be stored, and SRS warning light
will be turned on. When faults are detected, SRS warning light will
remain on until they are corrected and cleared from OBD.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Negative and positive battery lead together (minus the battery), but one of the previous posters might be right- SRS may be one of those that has to be reset from the OBD and there are no shortcuts for it.
- 9200 Views
Last post by spue
- 27 Replies
- 31181 Views
Last post by cn90
- 5361 Views
Last post by esl_97_850_T5
- 9391 Views
Last post by precopster
- 14 Replies
- 2912 Views
Last post by bmdubya1198
