S40 2005 Intermittently difficult to start
45K. For the first time on Tuesday after work I had difficulty getting my S40 started. Battery is starter seem fine. After several minutes of trying (and cursing), it started right up. Thinking maybe I accidentally flooded it, I was very careful on Wednesday and had no problems. Thursday morning it started right up but after work it would not start. After about 5 minutes of trying and cursing it again started right up with no sputtering, like nothing happened. After work I had several errands to run and it started after each stop with no problems. It seems like sensor problem. Any ideas?
OEMVolvoParts
- Year and Model: ALL
Sounds like maybe the the car is not recognizing the key randomly. The place you put the key in when you go to start the car is a pretty common replacement part for this car. It will go bad for some reason and cause an issue like this.
- 18 Replies
- 5107 Views
Last post by difflock54
- 508 Views
- 2619 Views
Last post by kosh_al
- 1117 Views
Last post by Stoneworks
- 3305 Views
