2001 s60 na engine codes
stat435
Year and Model: s60 2001 na
Post by stat435 »
i am in need of help with my car a few days ago i moved my car inside the garage when i put the car in park it began to shudder badly and was on the brink of stalling and would not accl to more than 35mph, along with all these issues i also recieved a message saying engine system service urgent. I got a code scanner and pulled codes p032 p037 p1026 p1610 and p1620 . I know the first two codes are for o2 sensors (although i just replaced them) but my main question is trying to determine what p1026 and p1610/20 are. I was told this is a etm related issue, and i have had my etm software updated (not replaced) but since i had it done the car was idiling unuasally high (in the 1100-2100 range) so my nearest dealer(200 miles away) told me if it was etm related they would pay for towing and fix it free of charge, but if it was something else the charges for towing labour and diagnosis would be upon me. so i need to be sure it is the etm because i cant afford to have it towed or worked on (college freshman) I need to get to the bottom of this because now i dont have a car and they want to pick it up as soon as possible.
any help is greatly appreciated matt
stat435
Post by stat435 »
Well the dealership did replace the throttle body and replaced the fuel pump because they said it was leaking, and they did all of it with no charge to me wich is great. But they also pointed out that I have a vacuum leak in the fuel injectors.
"has a large vacuum leak in fuel injector seal . est fuel injector seals with harness (broken connector) will cause cel to come on until resolved."
So is this just new seals that are needed or does this also include the harness. also how to replace the seals would be appreciated.
thanks. Matthew
