Just replaced headliner in Wagon
schigara
Year and Model: 96 850 T5 Platinum
Post by schigara »
And it was a pain! Getting the headliner shell out was easy enough but getting the new material to fit in the concave areas was quite difficult And cutting out for all the holes took forever.
It was hanging down in the left rear seat area and bugged me so I had to change it. I had changed a few headliners before in much smaller cars so I thought a few hours would get it done. It took a few more hours than I thought.
Of course, I could not find the same material but did manage to find a spot on match in color in the same material that is being used in most new cars. It cost me $47 for 3.5 yards of headliner and $60 for 3 cans of 3m Super Trim Adhesive #08090. I tested the glue with a small piece first. I sprayed the glue on both surfaces, waited 15 minutes and then stuck the test piece to the headliner shell and waited an hour. After an hour I tried pulling it off and the fabric ripped away from the foam backing. This was the right glue.
Everything came apart easy except for the visor hangers. They snap in and the only way I found to remove them, even after getting one out, is to just pull on it very hard and hope it doesn't break. Luckily neither one broke.
Has anyone here paid to have a wagon headliner replaced? I am curious to know what they would charge to pull the headliner shell and replace the fabric.
Also, has anyone purchased or inquired about the moon roof opening trim? This is the piece that secures and trims the headliner. I want to replace mine as it is a bit dingy.
My next job will be to replace the headliner on the moon roof cover but I will wait a few days on that job.
voodoorobaz
Year and Model: 1982 Volvo 245 DL
Post by voodoorobaz »
WOW, looks great to me. not sure on the cost for a shop to do it but 10 years ago I paid 100 bux here in Phoenix for a headliner.
1998 Volvo S70-Gone
2002 Volvo S60 T5-Gone
2000 Volvo V70 XC AWD-Gone
1983 Volvo 245 Dl-Gone
1982 Volvo 245 DL
2013 GMC Terrain with 3.6l
2006 Cannondale Bad Boy Use for Commuting to work
dbo550
Year and Model: 95 T5-R, 98 V70
Post by dbo550 »
You did a top notch job on that, hope , mine looks that good when I do it. Did you use all of the adhesive or can you do it with less than 3 cans?
schigara
Post by schigara »
Thanks.
On a sedan, 2 cans would be plenty. On a wagon, 3 cans was stretching it. I wished I had had 4 cans. To get good coverage, you have to make 2 passes on each surface and I had to run it light in the flat areas. In the high stress/concave areas, I put it on a bit thicker.
dbo550 wrote:You did a top notch job on that, hope , mine looks that good when I do it. Did you use all of the adhesive or can you do it with less than 3 cans?
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Post by RobTheModd »
voodoorobaz wrote:WOW, looks great to me. not sure on the cost for a shop to do it but 10 years ago I paid 100 bux here in Phoenix for a headliner.
Ive been quoted anywhere from 120- 600$ for my 850 sedan. for the moonroof panel and roof. 800 if i wanted genuine volvo... I think for a 680$ break id go with the non volvo material. lol
BTW NICE JOB!!!! haha how much to do it to my car? Haha.
Actually, for a sedan. Would you say its easy for the average joe to do in his driveway on a sunny day, or should i just shell out the 120?
I can get the 3m cans of spray from work since we use them ALOT
schigara
Post by schigara »
For $120, I'd pay to have it done. Scrubbing off the old foam is a hassle and nasty.
wheelsup
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
That looks really good! Nice job! :D
