240dl 1990 tries to turn over-won't spark
jessie240dl
- Year and Model: 240dl 1990
any advise -battery is good, how do we check to see if the spark is getting to the coil?-car started fine the other day, i went to the grocery store and when I came out she wouldn't start
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
This may help:
If you need more help, post back.
Bill.
This may help:
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
luke_jones
- Year and Model: 1994 855 Turbo
Edit: dont mind me...this time I read the post and looked right over the title stating that it turns over. So my suggestion of cleaning the battery terminals wont make much difference. I'll stop talking now and stay out of Bill's way
jessie240dl
ok so last week when i posted i didn't mention that i had to be towed.. so a couple days later i was checking the fuses and decided to try turning her over again. she started right up so I pulled out of the driveway, turned it off then restarted to be sure- all was good. I drove away and in a matter of 2 1/2 miles the check engine light came on and I lost all power-not gradually mind you but all of a sudden. I pulled over and turned on the lights making sure the battery had power it did but again the car would not start-had to be towed again! Does this type of behavior point to any one malfunction? Should I and how do I check the fuel filters? What else?
- billofdurham
If you aren't getting a spark it can't be the fuel filters.
The Check Engine Light (CEL) came on. What fault codes were stored? You can check this yourself using the On-Board Diagnostic (OBD) unit in the engine compartment. This is a first step in diagnosis. If you need to know how to use the OBD see here. There is a .pdf file in the 4th post.
Bill.
Bill.
Previously:
Previously:
jessie240dl
Can this be found in the Haynes manual?
- billofdurham
Possibly but the link I gave you has it all. The procedure is the same for the '89 and the '90.
Bill.
Bill.
Previously:
Previously:
