Transmission issues
iflewjetz
Year and Model: c70 2002
Post by iflewjetz »
I have a 2002 C70 Convertible. I have been having problems recently on shifting from reverse to drive. The car is fine going into reverse, but when put into drive it hesitates for about 2 seconds then "clunks" into gear. I just took it to a local transmission shop. They said it is the valve box? He said with parts and labor it would be $2100!!! The computer told him 10 hours to take out and replace, at $75 an hour. Does this sound normal? I have never replace a transmission in any car, so I dont know. My Dad had to on his truck but the whole thing was about $2000. I guess Volvos are more expensive. Thanks for any replies.
Also:
https://www.matthewsvolvosite.com/forums ... 15&t=24761
and
https://www.matthewsvolvosite.com/forums ... 15&t=24760
And
https://www.matthewsvolvosite.com/forums ... 15&t=24763
xjrguy
Year and Model: 2004 C70
Post by xjrguy »
iflewjetz wrote:I have a 2002 C70 Convertible. I have been having problems recently on shifting from reverse to drive. The car is fine going into reverse, but when put into drive it hesitates for about 2 seconds then "clunks" into gear. I just took it to a local transmission shop. They said it is the valve box? He said with parts and labor it would be $2100!!! The computer told him 10 hours to take out and replace, at $75 an hour. Does this sound normal? I have never replace a transmission in any car, so I dont know. My Dad had to on his truck but the whole thing was about $2000. I guess Volvos are more expensive. Thanks for any replies.
Also:
and
And
Did you check the ATF fluid?
Has the fluid ever been changed?
It could be something a lot simpler and cheaper and I would check the fluid level and condition first.
Maybe an ATF flush would help. Make sure you use only JWS3309 or Toyota T-IV fluid (they are the same thing) in that transmission!!
Owner LA Speed Garage forum
