All other running lights including headlights, parking lights, tail lights, turn signals and backup lights work OK but the stop lights do not work when the brakes are applied.
Fuse No. 4 which provides power is good and the brake light switch that
is operated by the brake pedal itself is OK. Since neither light works I suspect that the problem is ahead of the bulbs themselves.
Any suggestions or help will be much appreciated. Thanks, Rocky
940 1993 Stop lights do not work
940 1993 Brake Lights Do Not Work
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
This failure is often caused by a faulty bulb failure warning relay - the round one, back row left on the relay board.
Is the third brake light working?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
rocky334
- Year and Model: Volvo 940 1993
billofdurham, I followed your advice and "zingo!" it worked perfectly. The Bulb Fault Relay was in fact the culprit, after removing the plastic
cover on the cigarette lighter and the two underneath phillips screws & the small compartment just above the ashtray I had perfect access to the relay panel.
Quotes for a new relay averaged about $130 so I decided to open up the relay and found several questionable solder joints which I reflowed with small tipped soldering iron, the cylindrical relay cover easily slipped off and back on.
The big bonus of the entire project was that the total cost to me was
"zero" $$$$$$ and even further, the cruise control now also works
perfectly.
This forum is proving to be a priceless resource for a "shadetree" mechanic like me, again, Bill thank you so much. Rocky334
sli
perfectly.
sli
- billofdurham
You are welcome.
Thank you for the update which will help others with the same problem.
Bill.
Bill.
Previously:
Previously:
- 4835 Views
Last post by Amk20155
- 19 Replies
- 2535 Views
- 1875 Views
Last post by lummert
- 959 Views
Last post by selsworth1
- 627 Views
Last post by themtnman369
