Does anyone know what kind of special tool is required to remove the MAF from the housing?
I am following up on a string of MAF postings and suspect mine needs a good cleaning to sort out idle issues etc.
Any help or advice? I just spent half an hour at Pep Boys with a sales guy and no luck on finding the tool that fits right.
Thanks,
Sean
99 c70 Coupe Mass Air Flow Sensor Removal
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Do you need to remove it to clean it? MAF cleaner comes in an aerosol and is sprayed with it in situ. I haven't done it on a C70 but I have cleaned them on other Volvo models and other makes.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Yes, I am trying to remove it to clean it.
I disconnected it to see if it affected my rough idle and sure enough it is the source of my problem.
I bought the cleaner, but I could not find the right tool even at Pep Boys to remove it for the cleaning process.
S
S
SilverS70
- Year and Model: S70GLT-SE 2000
Is it hard to remove because the torx has the raised 'dot' in the middle?
If so, go to AutoZone and ask for Great Neck Part Number: TQR9C. $9.99 Thats what I did.
Looks like this
Its a Star Torx Set. Also know as a 'Tamper Proof' Security Torx. If my memory is right, its T20 size. You have to buy the set, nearly impossible to find for sale individually.
If you have a really clean, good brand of pliers, you might be able to grab the outer edges of the head of the bolt and twist it out.
Also, depending on mileage, cleaning a MAF is a short term fix, IMHO.
Looks like this
2000 S70 GLT-SE 161,000 Miles, original owner.
Once you get the 2 screws holding the MAF to the filter housing out, loose the clamp on the other side. Now the MAF should turn loosely but won't come out easily. Take a flat screwdriver and pry it out from the plastic hose. I think there is a small tab on the hose that will help you getting a grip. It's not going to be pretty, but once you install it back and tighten the clamp, it all should be fine.
- 13 Replies
- 10487 Views
Last post by jimmy57
- 975 Views
Last post by tamtam2122
- 2508 Views
- 1227 Views
Last post by jasontindal
- 1185 Views
Last post by 93Regina
