crankshaft position sensor-
confused_al
- Year and Model: 1996 TLA wagon
It looks S/V70 has a different CPS configuration, (#10 in both pics):
For S/V70 For 850 You still need to take the cover off then unplug the sensor.
BTW, the part you got is 9202134 right?
http://www.eeuroparts.com/Main/PartDeta ... id=9202134
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
I want to thank everyone, and yep that is exactly the same part which confuses me because I was calling it a cam pos sensor and was to it was a crank pos in a previous posting.. Anyway, I am currently waiting in a garage for it to be finished. Again, thank you to all that wanted to help. God bless
Old post, but I think the answer is incorrect. I believe the original poster is correct that #10 is the cam position sensor. Sensor labeled #11 in the diagrams is the crankshaft position sensor. I just got back from the dealer parts counter where I checked their diagram and purchased the CPS for my XC70. My symptoms are the car intermittently cuts out while running. It "feels" like an ignition issue as it is very sudden and will correct itself. If at idle it will stall, but start back up immediately. I had a similar failure in an old '95 940 that was the same part.
Well, my problem was not fixed by the crankshaft position sensor. I found that the vehicle will run with the camshaft position sensor unplugged. After unplugging the "cutting out" did not appear. I am thinking that my camshaft sensor may have completely failed and is giving an intermittent erroneous signal that is causing the "cutting out" or stalling.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
Brining up this old topic:
Who was OEM for the crank position sensor?
Thanks, Clemens
Thanks, Clemens
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Clemens
update: seems like VDO is OE. Can someone confirm that?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
This post suggests VDO is the OE:
viewtopic.php?t=58548#p297548
I just bought a VDO (Continental) crankshaft sensor from FCP, who list it as OE, and there is a spot on the insulation about halfway down the cable that has been abraded away by hand. This is sometimes a sign that a part was originally branded with a car maker's brand name and is being sold on the aftermarket at a discount to the dealer price.
- 5082 Views
Last post by regent
- 1298 Views
Last post by ducttapeandzipties
- 13 Replies
- 11598 Views
- 3569 Views
Last post by chrism
- 1370 Views
Last post by jimmy57
