interchangeable parts
Hi everyone. I am a new volvo owner-bought a 93 850 glt. It does run and drive but i want to make it better on a budget. Does anyone know if the parts including the engine and tranny interchangeable for all model years . will the engine from an automatic drop into a manual setup, etc. Thank you all and have a great day!!!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
What you have here is a'93 850 from a first generation and parts aren't quite the same like for later versions of 850.
Timing belt,headlamps,ecu's...aren't the same and,as far as i know,they are not in iterchangable with later models.
About your question for engine & transmission...As far as i know,they should be the same,but ecu's are not.
'93 models(first models of 850) have jetronic ecu's & later models have Motronic.
Also,in ecu box for '93 models there are 3 ecu's(for ignition,engine & transmission) and later models have only 2(for engine & transmission).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
They should be no problem at all so long as you swap the motor out between the manifolds, I actually think the later motors through '95 would work as well but the '93 model cars are just different enough that I wouldn't want to bet my life on it.
- misha
Yes it will fit,but as i said before,ecu's are different.
Meaning...no ecu's=no start.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
9394volvo850s
- Year and Model: 93 850 5spd 94 850T5
960 throttle bodys swap over for better response. 850 turbo cat back exhaust is slightly larger, weld on after the cat. 94 and up na 5 cyl exhaust have a better flow design then the 93, weld on in front of the cat. tail lights can be swapped over for an updated look.S70 and V70 have a little more agressive bulge in the side skirt and are a direct bolt on with S70 V70 mud flaps. all 93s seem to be wired for the side marker that goes in place of the volvo emblems on the front fenders found on most Volvos 98 and newer.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k
- 11 Replies
- 6506 Views
Last post by erikv11
- 1413 Views
Last post by MadeInJapan
- 2169 Views
Last post by June
- 3079 Views
Last post by skloon
- 19 Replies
- 4963 Views
