850 chocolate milk on oil dipstick
Does anyone else with an 850 have milky brown deposits on their oil dipstick and in the dipstick tube? When I check the oil I notice that on the dip stick there is milky brown stuff on it, and I can see it on the inside of the dipstick tube. The oil reads fine on the end of the dipstick like it is supposed to, and the oil when changed is not milky. Could this be an indication of the flame trap system being clogged?
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
Moisture trapped in the crankcase will give that symptom. It sounds like the crankcase ventilation system may be plugged. As a first step, try checking the flame trap if you car has one. It's in the plastic elbow that connects to the side of the throttle body elbow.asummers wrote:Does anyone else with an 850 have milky brown deposits on their oil dipstick and in the dipstick tube? When I check the oil I notice that on the dip stick there is milky brown stuff on it, and I can see it on the inside of the dipstick tube. The oil reads fine on the end of the dipstick like it is supposed to, and the oil when changed is not milky. Could this be an indication of the flame trap system being clogged?
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Driving a car in a short distances(less than 7 miles)frequently in cold weather gives that "milky" dipstick.
It's normal during cold weather.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xb corp
- Year and Model: 855GT5 '96
i afraid that is sign of leaking headgasket...water mixing with oil..
'96 855GT5 324hp 386lb-ft
Nissan 16V turbo, HKS w/g, SS 2.5" d/p+FGK 3" exh, HKS Evo9 FMIC+2.5" piping, K&N, Apexi BOV, NA cams & t/b, portd head, 5 sub-injctrs, Mocal coolers, AMG 4pot 325mm, AVS 18", Bilstein B6/Vogtland
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
Don't fret to much, mine has been like that for the last 60,000 KM(as long as I've owned it). I have used no fluids and have no leaks, performance is good; oil drains clean. It is ALOT worse in the winter time here; I feel it is moisture from an imperfect seal at the dipstick.
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
No I doubt that it is the headgasket. Milky oil seems to be pretty common in the colder months with the 850's. If it was the head gasket you would be losing some coolant.
Colonialgirl
- Year and Model: S-70, 1998
You might want to take it in to a mechanic and have them run a pressure check on the cooling system; If the pressure holds, that would eliminate the head gasket as the problem.
The other cause might be driving very short distances in cold weather where the oil never gets up to a high enough temperature to drive off the residual moisture.
A new o-ring on the dip stick, Hmmmmm. Thanks! I will take a look at it tonight and see. It does seem like it is just inside the tube. And, there is no water/oil mix when I change the oil.
polskamafia mjl
I would say 99% chance it's just condensation from the cold and not the head gasket.
- 12 Replies
- 2773 Views
Last post by charleskennedy23
- 1077 Views
Last post by RAS69
- 22 Replies
- 4644 Views
Last post by newbieofthenorth2+
- 378 Views
Last post by Ozark Lee
- 54 Replies
- 18796 Views
Last post by erikv11
