Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
How to use the On-Board Diagnostic (OBD) unit.
- billofdurham
- Year and Model: 855, 1995
- Has thanked: 0
- Been thanked: 3 times
The 400 series, with some exceptions, was fitted with an On-Board Diagnostic (OBD) unit from the 1990 model year. The unit is located in the engine compartment and allows the owner to read Diagnostic Trouble Codes (DTC), more commonly called fault codes, which have been stored.
The attachment contains the instructions for its use. Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- Year and Model: 440 GLT Turbo A '95
- Has thanked: 0
- Been thanked: 0
Re: How to use the On-Board Diagnostic (OBD) unit.
Hi there,
You say that the obd isn't fitted to 1.7 petrol turbo's, but my '95 glt turbo auto's got one.
Haven't tried it out yet though, but i will do and let you know if you like?
ps either way, very good article thanks for posting it.
Rob
Rob
- billofdurham
- Has thanked: 0
That is very interesting as my programme blanks out the OBD section when I select the 1.7 turbo model.
If you do try it I shall be very interested in the results.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
I have tried the obd out and with reference my post rough idle, high emissions, low mpg it did indeed work and came back with one fault code: 113 (injector wiring open circuit).
Bill, this makes sense to me as the problems i'm having would be associated with a faulty injector circuit. Do you think?
Maybe your system doesn't register turbo's as i believe they have two ecu's, guessing at one for spark and one for fuelling, so the "extra" ecu would possibly be the spark one as the fuel circuits are obviously connected to the obd, hence my fault code. If the fault codes mean the same thing on turbo models that is! Of course i could be completely wrong on this.
So it appears when i have some daylight i'll be hunched over the injector rail with the circuit tester, whatever my results i'll be posting them but i hope it is this simple!
Rob.
Rob.
- billofdurham
- Has thanked: 0
Thank you for that, Rob.
The codes do mean the same for turbo and non-turbo but the turbo usually has more codes.
It is only the 4 series that blocks out the codes for the turbo models on my programme. Every other turbo, including non-Volvo shows them.
The resistance range you are looking for at 20C should be 14 to 17 ohms.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Thank you Bill,
Slightly confused though, you say resistance should be 14 to 17 ohms, the pdf you posted some time ago ref fault code 113 says 1.1 to 1.5. Or did i write it down wrong?
Rob
Rob
- billofdurham
- Has thanked: 0
You wrote it down right but that was for a single point injection system on a 460 1.8.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Hello again,
I disconnected the wiring plugs from the injectors and measured the resistances. The wiring plugs were either 14.1 or 14.2, the injectors themselves were all 16.1.
It was a little colder than 20C though. Is the anything else i could try?
Many Thanks.
Rob
Many Thanks.
Rob
- billofdurham
- Has thanked: 0
The values are close enough.
The only other thing to check is the signal to the injectors.
Ignition OFF.
Disconnect the injector plugs.
Connect a LED test lamp to each of the plugs in turn.
Briefly crank the engine.
Check that the LED flashes.
If the LED doesn't flash check the wiring.
If the LED flashes there is a possible fault in the injector.
Bill.
Ignition OFF.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Thanks Bill,
I'm totally self taught so can i clarify please?
You suggest using a led test lamp, is this because an led will only light at a pre determined voltage and an ordinary bulb will light at a lower voltage?
I take it i can't use my circuit tester as it won't be able to keep up with the "pulses"?
Would any 12v led bulb and some lengths of wire do?
Sorry to be a pain and thanks again, Rob
Anyone use Total Car Diagnostics TOAD OBD II Software?
by bugs11 » Thu Mar 24, 2016 10:55 am » in VIDA, VADIS, DiCE - 1 Replies
- 1984 Views
Last post by Sommerfeldt
Thu Apr 14, 2016 11:27 am
a/c leak. Use or don't use stop-leak product?
by JimBee » Fri Sep 14, 2018 8:05 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 20 Replies
- 805 Views
Last post by JimBee
Mon Sep 17, 2018 4:50 pm
Rusty floor board
by seanj » Sun May 01, 2016 6:59 pm » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 6 Replies
- 835 Views
Last post by seanj
Wed May 04, 2016 7:40 pm
ETM code scanner for ETS light and advise if board damaged
by Awan » Mon Apr 24, 2017 8:34 pm » in The ETM Room - 6 Replies
- 1793 Views
Last post by Martyans
Fri Apr 28, 2017 2:01 am
