Hi again guys,
My 1998 T5 has had trouble releasing the drivers side hood release since I have owned the car. When I pull the hood release lever in the car if I don't put upward pressure on the hood simultaneously then it will not release, also if I hold the lever in the cabin and have someone open the hood at the same time that also works. I lubricated the release mechanism on the driver side and that helped slightly but it is still hit and miss; especially in the cold and when the hood is loaded down with snow and ice.
Any quick fix? It frustrates me!
Thanks,
- Jesse
Hood release
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I'll be interested in this too! My car recently started having a similar issues where I'll pull the lever and hear it pop, but it is then very sensitive to movement. If the lever goes back too far or the car or the car gets tapped, the hood will lock back. I have to pull the lever, and let it back really slowly, then run to the front of the car and pull straight-up.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
IVIUSTANG
Sadly my car makes very little pop, and my hood makes VERY little movement. I am not missing the two rubber pieces on the front of the good either that hit on the plastic above the rad, a simple fix for me would be to somehow exert more upward force on the hood from underneath, but no doubt someone knows better
Yes I have also done the release very slowly/run without jiggling car method on occasion.
- Jesse
- Jesse
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
Three things:
1. you may be able to adjust the cable at the handle by removing the kick panel and turning the adjusting nut (it takes an open-end wrench)
2. move the driver side latch DOWN about a millimeter (takes a socket wrench)
Those are the official ways, but...
3. the thing that fixed this exact same problem for me when the two above did not - the rubber pad on the bottom of the hood gets hard and compressed over time and doesn't provide any upward force when the latch is released. I fixed my problem by gluing a 2 millimeter thick piece of rubber onto the pad to make it a little thicker. I got the rubber by cutting up a rubber washer I had laying around. The pads, one for the driver side and one for the passenger side, are about one inch square and are easy to see when the hood is open. I didn't do anything to the passenger side.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
These are good way to fix. The same problem happened to my car, I'll try these. But before reading this message, my way is to use a plier to hold the release level when opening the hood. Only need to remember to take the plier away when the work is done.instarx wrote:Three things:
IVIUSTANG
I moved the driver side latch down and it works perfect thanks, although it did throw off my hood alignment with my quarter panel ever so slightly.
Thanks,
- Jesse
Thanks,
- Jesse
- 819 Views
Last post by pearlywhite01
- 21 Replies
- 7880 Views
Last post by bmdubya1198
- 1651 Views
Last post by cn90
- 514 Views
Last post by vtl
- 18 Replies
- 3254 Views
Last post by j-dawg
