Info on worn shaft. Aw 30-71 gearbox
Sharpy
Post by Sharpy »
Hi just wondering what the out shaft does as one is worn and the other is very worn, looks like a badly worn starter motor shaft where the brushes run. thanks I think it maybe something to do with the pump.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
They are badly worn.
Which pump?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Sharpy
Post by Sharpy »
The pump directly behind those shafts. Thats what the download i have says it is. Will it be ok to install that gearbox with the lesser worn shaft at all? What runs/grabs that worn shaft anyway, Thanks again
billofdurham
Sorry about that question - my brain had lost a gear and gone into neutral.
Auto boxes are very complicated to describe. The attachment is one of the easier descriptions I have found. Thanks to familycar.com.
240 Automatic transmission.pdf
(33 KiB) Downloaded 103 times
The inner shaft doesn't look too bad but the outer shaft is definitely in need of replacement.
Bill.
Previously:
