My cruise control doesn't work and my abs light is on - I pulled my codes and got a 1-4-1. I read the tutorial and replacing the sensor seems easy enough...but where can I get one? My local auto parts stores do not have it, IPD doesn't nor e-bay (on a quick search). Ya'll think one from a salvage yard would work or is it a stealership item?
Thanks,
Dale
1995 850 T5 wagon
Brake Pedal Position sensor
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
FCP should have it and yes one from a yard should be ok.
- Year and Model: Many Volvos
- Been thanked: 76 times
There was a great writeup on Ozbrick on how to repair the switch itself but the pictures seem to have vanished. It still may be helpful from the text.
http://webspace.webring.com/people/mo/o ... 41142.html
Even if you just replace it be sure to bleed down the vacuum on the brake booster before you remove the switch (Just hit the brakes a dozen times or so with the engine off). The vacuum will suck the O ring into the booster if you don't.
willowdog
- Year and Model: 95 850GLT, 85 360GLS
Hi
Just did mine. Essentially as the writeup says - get rid of booster pressure, pull the sensor out, get it apart (the hardest part of it!
) and resolder the connections.
I had 141 and 142 from memory. Now no codes, no ABS light, and cruise & TRACS work again.
While you're there, reset the service light if you havent already.
Cheers
Cheers
- 5177 Views
Last post by Raindog92
- 5302 Views
Last post by precopster
- 7259 Views
Last post by zjevik
- 3834 Views
Last post by Goldchemist
- 15 Replies
- 19096 Views
