Back-up lights don't light 240 Auto, 89"
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
edvanb
Year and Model: 240 89'
Post by edvanb »
Back-up lights fail to light. 89' 240 auto . Both bulbs are good. Switch under console shifter should turn them on when "Reverse" is selected. This switch also prevents start up in gear. How can I determine if this switch is bad before ordering another at considerable cost $$. ? The wires on this switch disappear under the carpeting. Is there a connector under there which would come with the new switch.??? Help.!!
edvanb
Post by edvanb »
This is NOT a reply...simply a notice to those that see my problem which I have solved myself. The reason my back-up lights did not work is because the printed circuit board inside the tail light assembly was corroded Therefore the multi pin connector that plugs onto the PCB could not make good contact to bring the +12 volts to the bulbs. I found a website called: www.vlvworld.com that not only carries the entire tailight asm. but also new Printed ckt. boards. Ordering the new PCB @ $19.88 will correct this corrosion proble. Thanks for your help. Ed :D
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Thank you for the update. How I missed your original post can only be put down to advancing years.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
