This issue is different from the one involving the amp
It never seems as though there is enough electricity to run everything.
When the heated mirrors get clicked on the lights [even headlights dim a bit]
When the blower motor goes on the dash lights and head lights dim
when the radio is loud and hits a hard bass note the lights do the same thing
i am wondering if there is a relay that is responsible for this or if its something a lot less simple.
1998 s70 t5 Power issue
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
When the lights dim, does it only do it when you first turn on the accessory or does it stay dimmer? It is normal for the alternator to have to adjust to a higher power load momentarily, but it should brighten back up almost immediately. Try using a capacitor wired between your battery and amp, it will help your battery and alternator have a much smoother load with less pulsing.
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Step 1: Battery test
Step 2: Alternator test
Then look into the cables. Just dirty clamps will cause problems.
The main battery (B+) cable on these cars is a known issue.
With 11 years behind it, it's probably corroding someplace.
Sometimes you can't even see it without cutting them open.
Call DW for a price. Then put an hour or so aside for the job...
Check the neg cable, too. It's just as important.
IVIUSTANG
I'm sorry I thought you had an aftermarket amplifier. The factory unit shouldn't need a cap, but it will only help. Capacitors can be bought at any car audio store though. Regarding your amp draw from your other post, wire in a solenoid that is activated in position 2 of the ignition switch and have it also wired into the amp. This will stop 100% of the draw when it is not on. Multiple solenoids are not that uncommon in my world and work well in my opinion. Wire a solenoid into say... the cable going to the back of your stereo that will turn off any power going to your amp in position 0. As far as how to wire up a solenoid or which one to get, someone else better qualified can answer that, but this WILL fix your "amp amp" draw
The main reason I have more than one solenoid hooked into my aftermarket mods is to allow multiple conditions to have to be met for the system to activate, for example: my methanol injection solenoid turns on when the boost switch solenoid detects 3 PSI boost, BUT... I have another solenoid that will disable the pump once the pressure is at 140 PSI, both of these solenoids must be active for the pump to get any power. This is my preferred and cheap bypass option for annoying electrical problems. My HHO system is activated by a solenoid that is tapped into the headlight bulb socket, basically piggyback a system that turns on and off at the desired times.
- Jesse
- Jesse
- BEJinFbk
Don't worry about adding a cap or a "solenoid" that you don't need.peacock wrote:I will look into both of these, a combination of each will probably do wonders.
Where to do I find a capacitor to place in the car?
Stay on the path to Stage 0. Fix the car. Don't confuse the issue by adding extra stuff.
Keep it simple. Get it back to running the way the factory designed it to.
Consider that Tens of Thousands of other Volvos run just fine without any extra parts.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I'm thinking the battery cable idea is a good start. Honestly, it still sounds like an old alternator, I had cars that did the same thing under load, and ended up replacing the alternator in them both. My Volvo still has the original one though, and nothing makes a difference turning on except when I turn the fan up fast in the morning (I think it has a sticky motor and a hard time getting started). But the radio, defroster, all power windows at the same time, etc. don't make a difference in idle or dim ANY lights when all activated at once.
Just some food for thought
'98 S70 T5
2016 Chevy Cruze Premier
jablackburn wrote:I'm thinking the battery cable idea is a good start. Honestly, it still sounds like an old alternator, I had cars that did the same thing under load, and ended up replacing the alternator in them both. My Volvo still has the original one though, and nothing makes a difference turning on except when I turn the fan up fast in the morning (I think it has a sticky motor and a hard time getting started). But the radio, defroster, all power windows at the same time, etc. don't make a difference in idle or dim ANY lights when all activated at once.
I just replaced the alternator a little over a year ago.
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
- 4158 Views
Last post by jonesg
- 853 Views
- 127 Views
Last post by MismatchS70
- 486 Views
Last post by aek0121
- 24 Replies
- 6485 Views
Last post by cn90
