Okay so I f'ed up.
While replacing bulbs I thought I could clean up the corroded connections with some dielectric grease. Later I learned that this was a bad idea and not the right ointment for the job.
Now it seems i've shorted something out.
My front turns do not work at all but parking lights do come on and are brighter like the turns are on all the time.
The rear turns click rapidly
When the hazards are on they click normally but only the rear lights work. Nothing up front.
I cleaned the terminals out and tried another hazard/turn relay switch.
Neither has worked. Any suggestions?
Any help is appreciated.
Nathan
96 854R Having a funny problem with my front turn signals
- misha
- Has thanked: 155 times
- Been thanked: 432 times
When any of turn signals blinks faster that means that the other side is not working.
For example...when you turn on left side turn signals and one of them blinks faster,that means that the bulb on not working turn signal is blown or bad.
Replace the bulb on not working one and you'll be fine.
If that doesn't help,check the fuses for turn signals.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
Make very sure that the bulb(s) is/are inserted properly. The nubs on the side of the lamps are slightly offset and it is possible to put them in the wrong direction but they will never work properly if you do so.
- 1772 Views
- 2122 Views
Last post by mecheng
- 1070 Views
- 1030 Views
- 607 Views
Last post by cjrayburn1
