S70 Volvo 1999 Peculiar Warning Symbol on Dash
I just purchased a used 1999 S70. Of course, after everything's all taken care of, my yellow "service" light came on. In addition to that, a red light with what looks like the symbol for water appeared; it has some sort of "flag" sticking up out of the water. The light is on the right side of the dash. I don't have a manual and was wondering if anybody knows what that symbol means? I checked all my fluids, and they look fine.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
The Service light is just a mileage activated reminder for oil changes and such.
There are reset instructions for it around here somewhere...
The other is probably a low coolant light, but here's a link to your manual, just to be sure:
http://new.volvocars.com/ownersdocs/199 ... 70_000.htm
Thank you so much! I just drove the car down from NY to GA; my husband noticed that the coolant level was a little below the half-way mark, but there's still some in there. I understand that Volvos use a particular kind of coolant. Do you know where I can purchase it? Are there any comparable substitutes? Your reply to my origial post got cut off, so you may have answered this already...
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
You can the Volvo coolant at a dealer. That's really the only place I know to get it, and my dealer is 50 miles away. I just run entirely Prestone in mine, but it's probably better to not mix them. If yours is a ridiculously dark green color, that's the Volvo coolant in there.
As far as resetting the service light, you're in luck! With a 99, all you have to do is hold the odometer reset button down, then stick the key in and turn it to position II (don't start). Continue holding the button, and the Service light will flash and it is now reset.
'98 S70 T5
2016 Chevy Cruze Premier
i own a 1998 s70 and none of the reset instructions any ware have worked for my system.
theres an even odder symbol on the dash its a red background with a green triangle and a black Lambda inside.
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
jblackburn
It won't work on a 97 or 98. You have to buy a special service light reset tool for that. Believe me, I've tried too
I'm just going to yank the bulb this summer when I go in there to fix a burned out light and change my evaporator
I've never seen that light you describe before, even with the whole dash lit up.
'98 S70 T5
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Isn't the Lambda symbol the check engine light in other parts of the world??
- misha
- Has thanked: 155 times
- Been thanked: 432 times
That light is check engine light at the rest of the world(except u.s.a).jablackburn wrote:I've never seen that light you describe before, even with the whole dash lit up.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
Like I said. lol
- 18 Replies
- 2850 Views
Last post by WhatAmIDoing
- 2076 Views
Last post by MDK
- 760 Views
Last post by Vovo_merz
- 473 Views
Last post by 800artfreed
- 1737 Views
Last post by E Showell
