No whipers/washer on S70
Just got a 1998 S70 and after washing the car discovered that the windshield whipers and washer aren't operating. moving the control lever doesn't have any effect at all. I don't think it's a fuse as the horn -listed as on the same fuse - works fine. So.....???
perhaps the relay is dead, or the Stick [lever for the wipers] is it self broken. the plastic around the steering wheel pops up allowing you to get access and take it out to check
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
On an 850 the relay is number 203 and it's blue (I'm color blind so I might be wrong). The realys are underneath the driver side dash. You have to crawl under there, undo 3 t-25 screws and drop down the knee bolster. Then you have to crawl way under the foot well and you will see the relays inside.
- 15 Replies
- 8910 Views
Last post by volvolugnut
- 36 Replies
- 25009 Views
Last post by StickyPocket
- 2211 Views
Last post by kdaide
- 530 Views
Last post by ZionXIX
- 1164 Views
Last post by BigRed
