Powerstop brakes
t5rrr
Year and Model: 1994 855
Post by t5rrr »
Just install a set of Powerstop drilled/slotted rotors and ceramic pads at all 4 corners 8)
Front:
Rear (it's copper grease on the hub):
Pads:
Wagon Brigade >> 94 855 NA | 97 Subaru Impreza OBS | 07 Suzuki SX4
Previous Bricks >> 90 240 GLE 2.0 | 98 S70 T5A 2.0 | 03 XC90 T6 2.9
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Looks good. Let us know if there's brake squeal noise.
Also -> Amazon link
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
let me know how they work out. Im gonna be doing a similar setup with ss braided lines.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
t5rrr
Post by t5rrr »
matthew1 wrote:Looks good. Let us know if there's brake squeal noise.
No squeals thus far. I did gob plenty of silicone based brake grease on the pad backing plates, slider pins and caliper brackets where the pad "ears" rest.
At the beginning there was some grinding feel in the brake pedal with medium braking pressure that went away after about 3 days. My 2 cents on that is it was probably the new pads bedding in and "surfacing" the drilled/slotted rotor. :)
9394volvo850s
yes thats what the noise is. ok glad it is working out so far.
rbodor3
Year and Model: 01 S60 LPT
Been thanked: 2 times
Post by rbodor3 »
it also helps to paint the rotor hats in the future with some VHT spray, it helps prevent rust buildup and makes them easier to remove the next time you install.
01 Volvo S60 2.4T
t5rrr
Post by t5rrr »
rbodor3 wrote:it also helps to paint the rotor hats in the future with some VHT spray, it helps prevent rust buildup and makes them easier to remove the next time you install.
This is a good tip for most aftermarket replacement rotors.
The rotors I got have zinc coating on them so that should keep the rusting to a minimal, I did however put copper grease on the back side of the rotor hats where it meets the hub to prevent any chance of it getting stuck. :wink:
850_olaf_nz
Year and Model: 1997 855-T5
Post by 850_olaf_nz »
I've been searching, and found very little about these rotors on our Volvo application. How did they work out for you? Would you buy them again?
http://www.powerstop.com/product/power- ... nt%20Discs
I bit the bullet and ordered from Amazon yesterday, the per-pair pricing was compelling. I'm assuming the quality is good enough. I'm going to use them on my '97 855-T5 (front and rear) with PBR Deluxe pads. Replacing lines (braided), slider pins and boots, rear shims and clips, fluid.
regards
1997 855-T5, 182k km, as stock as a stock thing.
