2008 S80 wheels
I just bought a 2008 S80 with 18" wheels and low profile pirelli tires. In my opinion they ruin the ride. Am I asking for trouble if I go to a 17" after market wheel and a higher profile tire? Performance buffs in the audience will have to excuse me - the ride is more important to me!
kevmcrae
- Year and Model: 2007 S80 3.2
I have a 2000 that came with 16's. I kept them for my winter tires and got aftermarket chromed aluminum 17's for my summer tires. The 17's don't have a bad ride at all. I just bought a 2007 with factory 18's. While the ride is more firm I don't find it too rough for this 48 year old!
Talk to a tire shop and just make sure your diameter is the same and you shouldn't have a problem with the 17's. The only thing I have to contend with on my 2000 with the aftermarket wheels is they are difficult to balance perfectly. Tire dealer put hub rings on them and has been better since then. But you must buy good name brand tires. The cheaper ones won't balance out right.
What factory 18" rims do you have? I may be interested in buying if they are the chrome!
Kevin
Kevin
I have had my 2007 S80 for 5 months. It came with 17", VERY wide, low profile tires. These are the widest, and lowest profile tires I have seen; though at 61 I'm not as up to speed like I should be.
I have never felt the ride was as smooth as it should be, even with the suspension setting's selector. After reading your postings, could these tires be the cause of my not so soft ride?
meine39
- Year and Model: 1995 850 GLT Wagon
www.tirerack.com offers a number of 17" rims for the S80 (Matt has a link to tirerack that you should use so that the site gets some support money). tirerack ships from Delaware so if you're in PA you'll get your order pretty quickly.
Watch the weight of whatever wheels you buy - some of them are real tubbos - heavy wheels do NOT help performance or handling.
1995 855 GLT 190K NA Auto
1998 BMW 528im 137K
2000 Toyota Camry 78K
2010 GMC Acadia 57K
1998 BMW 528im 137K
2010 GMC Acadia 57K
kevmcrae
pj8708, the lower the profile tire the firmer the ride....that's for sure. Personally I don't mind the 18's on my 07 or the 17's on my 2000. But the smoothest ride is definitely with my 16 inch rims that I run my snow tires on my 2000. They are a higher profile, more side wall, so they absorb more impact.
- 847 Views
Last post by bbeels
- 661 Views
Last post by mk80634
- 1557 Views
Last post by Ben850
- 494 Views
Last post by Bostonfan49
- 875 Views
Last post by kaneelschep
