1998 S70, Aftermarket wheels: w/o alignment hole. Safety?
Just got a set of alloy wheels with snows for my 1998 S70. When I went to mount them I discovered the alignment pin in the stock wheel hubs. The new alloys don't have the "extra" hole in them to match up with the pin. It seems that the purpose of this pin is to keep the stud hole lined up when a wheel is removed. After some experimentation, I removed the alignment pin in the stock wheel hubs, carefully keeping the stud holes lined up, and then mounted the new alloy wheel. All seems OK but is there any safety issue that's involved with removal of this pin?
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
No, it's just there to line everything up to make it easier to install the wheel, as you have discovered. If you have room behind the wheel in that area, you can install a conventional bolt in place of the stud to hold the disc in alignment with the hub.
Thanks. That's what I thought, but being new to Volvo, I just wanted to make sure.vegasjetskier wrote:No, it's just there to line everything up to make it easier to install the wheel, as you have discovered. If you have room behind the wheel in that area, you can install a conventional bolt in place of the stud to hold the disc in alignment with the hub.
9394volvo850s
- Year and Model: 93 850 5spd 94 850T5
yea its for lineing up the stud holes your ok.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k
- 704 Views
Last post by lummert
- 864 Views
Last post by Ozark Lee
- 1955 Views
Last post by reverend
- 11 Replies
- 1870 Views
Last post by brunocerous
- 1099 Views
Last post by kranz
