IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
S70 glt, 98, Turbo oil leak
VolvoS70Driver
Year and Model: 1998 S70 GLT
Has thanked: 0
Been thanked: 0
United States of America
VolvoS70Driver
Post by VolvoS70Driver » Fri Jan 01, 2010 6:08 pm
Another issue found while doing the work under the car. I knew there was an oil leak at the turbo but figured it was the oil return tube/flange. I was prepared to change that and saw it had apparently been done and also the oil appears to be coming from something alittel higher up. Either where a little balck hose connects (at red arrow) or around the other component attached to teh turbo (in red outline) I really want to fix this while I have the axle out and can get to it relatively easy so any thoughts on where the oil might be coming from will be appreciated.
You do not have the required permissions to view the files attached to this post.
Doug
1998 S70 GLT Blk/Blk
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 8 times
Been thanked: 5 times
jblackburn
Re: S70 glt, 98, Turbo oil leak
Post by jblackburn » Sat Jan 02, 2010 7:43 am
Mine actually looks exactly the same way...I had previously never looked that far up under the car, until I was trying to figure out what the bad smell I was getting was coming from. That's from oil dripping down onto it probably from the rear main seal. Look under the spark plug cover. Is it filled with oil? Does your oil dipstick smoke when pulled?
You probably need to clean the PTC nipple/overhaul the PVC system as well. Yay more work! :roll:
'98 S70 T5
2016 Chevy Cruze Premier
VolvoS70Driver
Has thanked: 0
Been thanked: 0
VolvoS70Driver
Post by VolvoS70Driver » Sat Jan 02, 2010 10:24 am
I actually do have a new PCV box looking thing to replace but have yet to find where it goes. I was hoping it may help some but would also like to replace any seals down here while I have it this accessible. I may check that little black hose a little closer and see hose easy it might be to replace.
Thanks for the input.
Doug
jblackburn
jblackburn
Post by jblackburn » Sat Jan 02, 2010 10:28 am
The oil separator? Under the %$^% intake manifold...I'm not sure who decided to put it there, but I want to punch them in the face. I did mine last week, and its a pain when it's never more than 30 degrees outside and you can't feel your hands :mrgreen:
Here's what I followed to replace the system on mine: http://www.lakesidedp.com/uploadpics/pcv/index.html
'98 S70 T5
VolvoS70Driver
Has thanked: 0
Been thanked: 0
VolvoS70Driver
Post by VolvoS70Driver » Sat Jan 02, 2010 12:02 pm
Oh you just made my day. And I thought I would get this project finished today.
I had a fear that is where it would be located but was clicking my oily shoes and repeating "It's got to be in plain site, It's got to be in plain site........"
Very good set of instructions on that link though.. Thanks
With all the wet oil residue I'm seeing in the air intake hoses to turbo and intgercooler, plus the fact that it looks like oil is actually dripping out of the dipstick tube, I figure it's got to be this.
I also like the way the Chilton manual avoids mentioning this component entirely.
Doug
jblackburn
jblackburn
Post by jblackburn » Sat Jan 02, 2010 12:33 pm
Sorry about that :mrgreen:
I'm hoping it solved my oil problem for now, but there is STILL some pressure on my car, but it's much better than it was before. I'm going to try digging the PTC nipple out again and give it a good cleaning...if I can figure out how to get it out.
'98 S70 T5
VolvoS70Driver
Has thanked: 0
Been thanked: 0
VolvoS70Driver
Funny what you find sometimes... Re: S70 glt, 98, Turbo oil
Post by VolvoS70Driver » Sat Jan 02, 2010 3:01 pm
Got it all apart and found the blinking oil sperator.
Also found this little surprise. Guess it was warm hiding spot to build a nest at some point. Hopefully he's not still hiding somewhere.
Doug
chepada
Year and Model: s70 1998
Has thanked: 0
Been thanked: 0
chepada
Post by chepada » Sat Jan 02, 2010 8:25 pm
also check the sensor right at the air intake to the turbo, the hose that connect turbo to air filter , that sensor need to be clean up , and tight the hose clamp to the turbo, that's where the oil is coming from.
thesnows06
Has thanked: 0
Been thanked: 0
thesnows06
Post by thesnows06 » Thu Jan 14, 2010 7:04 pm
Doug,
Did you ever solve the problem with the leak around the turbo? I have a leak that looks almost identical to yours, and I wanted to you if you found the cause.
Thanks,
Tyler
jblackburn
jblackburn
Post by jblackburn » Thu Jan 14, 2010 7:36 pm
In my case, it was a clogged PCV system leaking oil down onto the exhaust manifold.
'98 S70 T5
