IPD sale Volvo Parts
XeMODeX - Experts in Volvo Electronics Volvo Wholesale Parts - genuine Volvo parts
Did you know? 🤔
Can the OBD reset the SRS light?????
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
wig
Year and Model: 850 T5, 1994
Has thanked: 0
Been thanked: 0
wig
Post by wig » Sat Jan 02, 2010 8:09 am
Hi there, I'm new to this forum, but very glad I found it! I have a 440 2.0i on a late N (96) Special Eds.
I had to replace the indicator switch and in order to do that I had to disconnect the airbag, not a problem until I had to drive the car without it fitted, to get a 24mm socket to remove the steering wheel!
Since then the SRS (airbag) light has been on. My own fault for being in a rush to get it done! I was just wondering if the OBD (on board diagnostics) system would be able to take the light off, reset the system? Or maybe :idea: (ill try this now and report back) if I disconnected the battery for 10 mins or so, and see if it resets itself????
Any help would be really useful and gratefully received!
I'll report back if disconnecting the battery works!
All the best, and thanks in advance,
Wig! :D
'94 850 T5 GLE
'95 440 GS 2.0i
Some do, Some don't, I might!
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
Re: Can the OBD reset the SRS light?????
Post by billofdurham » Sat Jan 02, 2010 12:49 pm
In case disconnecting the battery didn't work you can use the OBD to delete SRS codes.
Use socket 7 and follow the instructions in the "how to" in the announcements at the top of the forum.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
wig
Has thanked: 0
Been thanked: 0
wig
Post by wig » Sun Jan 03, 2010 4:00 pm
Hi Bill, thanks for the reply! The battery disconnection didn't work, and I tried the OBD in number 2 and tested, it came back with a 212 code, which does not fit in with the srs light, as per your 'how to' pdf file! I've run out of time for tonight, but ill try position 7 in the morning! I take it I just do exactly the same as Ive done already with number 2, just with the cable plugged in to number 7! (I've never messed with these before, so forgive me if I'm wrong!)
Cheers for your help!
Wig!
'94 850 T5 GLE
'95 440 GS 2.0i
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Mon Jan 04, 2010 12:49 pm
2-1-2 in socket 2 is the heated oxygen sensor. Read the codes again in socket 2 then erase any that come up. Run the car and see if the code returns.
Use socket 7 in exactly the same way as socket 2.
Bill.
Previously:
wig
Has thanked: 0
Been thanked: 0
wig
Post by wig » Thu Jan 14, 2010 1:15 am
Hi bill! I used the autodata disc at work, and 212 was the airbag light, in pin 7 like you said!
Many thanks for your help in this! Although the chart for the codes you have put up, seems to be incorrect for my vehicle! But still, it's all sorted!
Thanks again!
Wig :!:
'94 850 T5 GLE
'95 440 GS 2.0i
