IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
Low Beam Head lights not working
1996 - 2004 S40
1996 - 2004 V40
tsc1015
Year and Model: 2000 S40
Has thanked: 0
Been thanked: 0
tsc1015
Re: Low Beam Head lights not working
Post by tsc1015 » Sat Jan 16, 2010 1:35 pm
Along with my heat problem, I also finally fixed my headlight problem. I was unable to source the relays I needed so I went to the junk yard and got a used CEM, $40 bucks and it fixed the issue. So besides some dash lights that I need to replace and a passanger headlight assemlby that needs to be repaired the car is good to go.
JPinSanDiego
Year and Model: 2003 S40
Has thanked: 0
Been thanked: 0
JPinSanDiego
Post by JPinSanDiego » Mon Dec 07, 2015 3:27 pm
Did you have to take the ECM unit to a Volvo dealer to have it "programmed" to run with your car? I have a 2003 S40 and am beginning to worry that these unavoidable dealer charges are going to make the car extremely expensive to run.
Acminer2
Year and Model: 2003 s40
Has thanked: 0
Been thanked: 0
Acminer2
Post by Acminer2 » Tue Jan 19, 2016 2:12 pm
Did the CEM board have to have a number code that matched your car? I'm having the same issue and can't find a board
jakeman1111
Year and Model: v40
Has thanked: 0
Been thanked: 0
United States of America
jakeman1111
Post by jakeman1111 » Sun Jan 31, 2016 5:51 pm
CEM's purported to be refurbished on eBay are depicted with the label intact. Any one who has dug into a S\V 40 CEM knows that the label will most certainly be damaged during the process. So what constitutes "refurbished"? Wiping it down with Armor All?
Plenty of info out there that would tell you about the mechanics of de soldering and the soldering in of new board components.
Assuming you have Amaz.... Prime you can collect the following for around $60 US.
solder
new bulb connecters (the ones you have are probably baked/crispy/fragile)
shrink wrap tubing (assuming you would be replacing bulb connectors)
Desk top magnifier (small)
solder sucker
couple of new low beam relays
New light bulbs
and some 15A fuses (if needed).
Go ahead, you can do it, take on "THE MAN" and beat him at his own game and at the same time do a REAL refurbishment of your CEM..
derrick_d3
Year and Model: 2001 s40
Has thanked: 0
Been thanked: 0
derrick_d3
Post by derrick_d3 » Fri Mar 04, 2016 12:51 pm
I was wondering if you ever found a way to fix your lights without buying the cem?
heis2201
Year and Model: 2004 V70 2.5T FWD
Has thanked: 0
Been thanked: 0
heis2201
Post by heis2201 » Tue Mar 15, 2016 2:58 pm
Hi there,
I am facing the same issue, and was also wondering if someone has found a source for those relays?
heis2201
Has thanked: 0
Been thanked: 0
heis2201
Post by heis2201 » Tue Mar 15, 2016 3:09 pm
heis2201
Has thanked: 0
Been thanked: 0
heis2201
Post by heis2201 » Wed Mar 16, 2016 9:46 am
Another question I do have: Would changing the ECM mess up my electronic key?
heis2201
Has thanked: 0
Been thanked: 0
heis2201
Post by heis2201 » Wed Mar 16, 2016 9:49 am
For those ordering the relay in the US: http://www.alliedelec.com/search/result ... rm=jsm1125
I had to order minimum quantity of 5, meaning I do have 3 spare, just in case you are interested.
