Tire Scrubbing
I have a 2001 with factory 17 inch rims. I bought the car as a certified preowned several years ago and it has been a joy. At some point The front end began to sag and the front tires started scrubbing. My Volvo mechanic was very dimissive of this issue and said "they all do it". Well, my car didn't do it for many years and I don't find it acceptable. I'm replacing the struts and spring seats in the next couple of weeks but I am interested in knowing about other peoples experiences with this.
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
The problem could also be worn steering stops. They limit the travel of the wheel. You can try replacing them with stock factory stops or IPD's thicker stops. They're not expensive and are an easy bolt-on install on the front of the lower control arm.
Thanks! I have researched the stop limiters and I am certain that is the issue. I really apreciate it.vegasjetskier wrote:The problem could also be worn steering stops. They limit the travel of the wheel. You can try replacing them with stock factory stops or IPD's thicker stops. They're not expensive and are an easy bolt-on install on the front of the lower control arm.
- 23 Replies
- 1339 Views
Last post by BlackBart
- 596 Views
Last post by jreed
- 1034 Views
Last post by FLXC90
- 6005 Views
Last post by jrbettis
- 697 Views
Last post by brando_calrissian
