s60 turbo
cdo456
Year and Model: 2006 s60 turbo
Post by cdo456 »
When I start my 2006 S60 in the morning on very cold days it takes at least 30 mins before I can shift the gear box from parked to reverse. Also my key is hard to get out of the ignition when I turn the car off. HELPP!!!
DanZ51
Year and Model: 2005 XC70
Post by DanZ51 »
Sounds like your brake interlock solenoid isn't functioning. The solenoid allows the shift lever to move when your foot depresses the brake pedal. Keeps old ladies from crashing through coffee shop :lol: I haven't replaced one yet, but hear it's common failure. I would guess the solenoid is in the console, on the select lever.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
In the older cars like mine, the electrical portion of the ignition switch is a common point of failure, and acts up under extreme temperatures. Once you start the car, try jiggling your key a little bit and see if it unlocks. There is also a shift-lock solenoid that fails under the console, as mentioned above.
'98 S70 T5
2016 Chevy Cruze Premier
E170_Driver
Year and Model: bye V70 2.4T, 2001
Post by E170_Driver »
I am by far not an expert on working on Volvos, but a couple years ago my key would not turn in the ignition; I was told by some 'wise' mechanic to spray some WD40 on the key and into the ignition; I gave it a shot since the dealership quoted me some horrendous price for a new unit...long story short, that was over 2 years ago and haven't had any problems ever since...
Jan
Former 2001 V70 2.4T owner
