while i was attempting to repair my odometer i decided to remove the "service light" bulb. basically its annoying to me. My understanding its just a reminder to change oil ?
Anyways, on doing so and putting everything back together, before removing the insturment cluster i always had a CEL light on. Now, no CEL.
By me removing the service light bulb has that caused my CEL light not to work ?
removed service light bulb
- phils94850
- Year and Model: 2009 s60 turbo
1996 Platinum Edition
firekiller75
- Year and Model: 1997 850, 1998 S70
I removed the service light on my '98 S70 and my check engine lights still works. Maybe you had a one-time code that cleared out. Does the check engine light come on when you turn the key to the on position?
'98 S70 n/a with 187k miles, paid $300 for it!
'97 850 n/a wagon, girlfriend's cruiser!
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
1984 240 4-speed w/overdrive button
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
- phils94850
went out and checked.. no the CEL doesnt come on when i turn it too the "on" position..
I took out my service bulb too but the CEL still works. You may need to go back in cause it may have been knocked loose. Those are the little twist locks aren't they?
Thanks,
Mike
1997 850GLT
2010 XC60 T6
Mike
1997 850GLT
2010 XC60 T6
firekiller75
Yup, looks like it's time to pull the dash pad apart again!
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No,you don't need to pull out instrument cluster again.You can go under the wheel and remove plastic panel which is hold by 3 torx screws.After you remove it you can replace almost all instrument bulbs from underneath,except one of two bulbs for trip computer.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- phils94850
i went ahead and put the service bulb back in and now the cel is working ??? oh well, ill just reset the service light and go on... thanks for all the help !!
9394volvo850s
- Year and Model: 93 850 5spd 94 850T5
thats odd, in both my 850 i removed the service lights and the C.E.L. lights come on when the key is turned on.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k
firekiller75
Well said!Toplights wrote:Its a Volvo They are all odd,no two the same.
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
- 4144 Views
Last post by silentcircuit
- 1465 Views
Last post by JRL
- 1031 Views
Last post by E Showell
- 4874 Views
Last post by adrian22
- 2638 Views
Last post by firstv70volvo
