I have decided to keep him alive by buying a parts car with a blown motor and doing a swap. This car has a turbo which will still work. is it compatible with my non-turbo motor or will i just have to install it and be set?
Putting a turbo on a non-turbo motor
i recently hit a deer with my beloved car
- Year and Model: Many Volvos
- Been thanked: 76 times
Putting a turbo on a N/A block will blow it up, the compression ratio on the N/A is way too high. In order to drop your N/A into a car that previously had a turbo you will need to completely replace the wiring harnesses and the ECUs.
Your cheaper and easier alternative is to simply buy a used turbo motor and drop it into your new parts car.
- 830 Views
Last post by Cecil_
- 696 Views
Last post by 93Regina
- 12 Replies
- 3150 Views
Last post by 800artfreed
- 665 Views
Last post by amblerman
- 14 Replies
- 2285 Views
Last post by chelseabrentjr
