The tubing that goes from the top of the valve cover, down between the intake runners, over to the passenger side of the intake manifold, and elbows into the intake next to the power steering pump.
The elbow, that everyone has problems with, I have finally found out what you're talking about. Now I need to buy that elbow, or the whole line if I need to.
98 S70 T5 need part numbers of tube for PCV
- Year and Model: Many Volvos
- Been thanked: 76 times
I think you are talking about two distinct lines as you describe it. The line that comes down from the top of the cam tower, between the intake air runners, goes to the oil trap. The line with the crappy elbow goes behind the intake manifold and begins at the PTC valve and ends up on the far end of the intake manifold.
FCP Groton has excellent diagrams on lines.
JoJoDaClown
- Year and Model: 1998 S70 T5
Okay, but I don't see the elbow that I need in the diagram.
From part of your original problem description you described item number 15 as I read it. The other part, the elbow to the other part of the intake manifold is item number 13 (it isn't shown real well graphically as to its angle where it meets the intake manifold). If the line itself is broken then you need item number 7 but at that point I would just change it all with new parts and be done with it.
