I changed the oil on the wifes 98 S70T5 yesterday and now on occasion im getting a slight tick. I used castrol 10w30 syn. blend and added that "moly" additive to the oil. I can say the car seems alot more peppy with the additive and it starts no prob. with the cold weather.
Due to lack of time i couldnt get a volvo filter for it so i used a fram which was on the car prior. It didnt tick at start up or running. Now, after the oil change no tick at start up but it does a very slight tick occassionally while running. Anyone have issues after an oil change like this ???
oil change = slight tick
- phils94850
- Year and Model: 2009 s60 turbo
1996 Platinum Edition
meteg
- Year and Model: 2007 V70 2.0T
I think the reason is the filter.almost everyone on this forum says that oem volvo or mann filters should be used.. other filters will cause problems..
other friends will make a comment soon...
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
I can see a filter without check valve causing the startup tick you describe, but a tick while running is likely unrelated. I've had a continuous tick - stuck lifter(s) for several months now, ever since a SeaFoam treatment. It was suggested I try changing oil type/weight, but that didn't work for me. It might for you, though, along with installing a proper oil filter.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
JDS60R
- Been thanked: 3 times
Phil,
Change the filter to a Volvo or Mann brand (makes the Volvo).
I have seen this before and discounted it the first time it happened. Sometimes we would replace the new Fram with another new Fram and it would stop ticking. I have no explanation but because of this we stopped using anything but Volvo or Mann on the 850 back in 1996.
I would assume it would be a lack flow issue. We cut open the Fram's and we see no blockages other than the filter media.
I checked your owners manual and 10W-30 shoud be fine for the temps in Indiana right now.
Best Wishes and let us know how it turns out.
850_1994.pdf- (3.33 MiB) Downloaded 211 times
Retired
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
Your right on this, I will vouch for the Amsoil filter. Just thought someone other than a dealer should suggest that filtershilander wrote:Volvo, Mann, or AMSOIL EaO oil filters
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
- phils94850
thanks for the help everyone
.. ill get a mann filter and put on it.
- 16 Replies
- 2383 Views
- 1267 Views
Last post by jimmy57
- 11 Replies
- 16029 Views
Last post by RossJonnes
- 861 Views
Last post by 2008XC70
- 4038 Views
Last post by jtp
