Hello again
Just put in my new ETM three weeks ago...started the car today just fine but when I started out it wouldn't allow the rpm's to go over 1500...and would barely move...
i pulled over in the driveway and turned it off, waited 5 minutes and it started to run fine again...check engine light came on.
So When I pulled over after 15 miles I pulled the plug on the MAF, sure enough it dropped in idle for a split second then came back up and kept running. Is it a sure sign of a bad MAF>???
Limp home mode on new ETM... MAF?
daddysvolvobus
- Year and Model: v70 xc awd 1999
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
That car does NOT like you lately, does it?!
I've heard it's bad to pull the plug on the MAF when the car is running (but I did the same thing).
You can leave the MAF unplugged and go to get the code checked. Just go easy on the gas pedal, or it will shoot black smoke like a diesel. If that's the only code in the system, then it is probably the MAF sensor.
'98 S70 T5
2016 Chevy Cruze Premier
daddysvolvobus
Well if I can get it to run right with it plugged in Ill go get the code checked...
And NO the car hates me...Im wondering if Ill sell it!!!
daddysvolvobus
I got the Code P0237 Turbo/Super boost sensor...as soon as I had it checked the engine light turned off and its running fine again...
However, when I first started it to go get the code checked I had the idle jump several times "staccato" until it evened out at 950rpms...
As I have read Matthew1's post in Dons etm room about signs of a failing MAF it still sounds like its the MAF not some turbo sensor! Any ideas would be great...the bill for this car is getting ridiculous!
jblackburn
I was going to say that the not going over 1500 rpms sounded like a turbo issue to me. Usually a frozen intercooler or sucked-shut hose, but a stuck shut wastegate would definitely do it too. You may want to check your vacuum lines there if the issue re-occurs.
The idle issues still sounds like a MAF to me too though. Did you try cleaning it?
At this point, you've spent so much on those few things you did to it that you'd only be taking a loss if you were to sell it. Unfortunately, KBB values don't incorporate what new parts have been installed.
'98 S70 T5
daddysvolvobus
Havent cleaned it, but probably should try!
Ill search and see what the posts show...
I love my Volvo, it just needs to stop breaking and let me enjoy it!!!
jblackburn
I hear you there, I haven't really been able to drive mine much for the past 2 months...one thing or another keeps breaking every time I go back to NC to the point where I'm uncomfortable driving 3 hours on the highway in it, and I keep ending up having to borrow one of my parents cars.I love my Volvo, it just needs to stop breaking and let me enjoy it!!!
I know the sensor on a 99 is different, but the basic process is the same. Pick up a can of MAF cleaner and spray the inside of the sensor, don't touch anything. Let the sensor sit unbolted for an hour or two and reconnect it and see how it runs.
'98 S70 T5
daddysvolvobus
Cleaned the MAF using CRC cleaner and it starts and runs fine...for now.
We will see if that will stop it from going into limp mode again.
- 3340 Views
Last post by prwood
- 1053 Views
Last post by mechaman1
- 1671 Views
Last post by bmdubya1198
- 714 Views
Last post by mapdoc
- 704 Views
