Prepping for reinstalling head and have some questions
1) Headbolts look fine yet manual suggests replacing with new ones - wondering if everyone follows this instruction
2) "Volvo liquid gasket solution" is this only option for upper/lower head interface. Anyone ever use loctite 510 flange sealant?
3) For cleaning head gasket surface area on head can one use a fine scotchbrite pad or is that too abrasive
4) A friend suggested I include a light coat of aviation gasket sealer on head gasket surface as a belt and suspenders approach. While I like stacking the odds in our favor I am worried this may have some negative impact - anyone want to weigh in?
Tks Gary
Head Installation Questions 1995 850
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
1) Headbolts look fine yet manual suggests replacing with new ones - wondering if everyone follows this instruction. If the bolts have only been removed once, you can get away with reusing them. Personally, I would get new ones.
2) "Volvo liquid gasket solution" is this only option for upper/lower head interface. Anyone ever use loctite 510 flange sealant? Do not use loctite sealant. I think you can use RTV but the volvo stuff would be best.
3) For cleaning head gasket surface area on head can one use a fine scotchbrite pad or is that too abrasive That should be ok.
4) A friend suggested I include a light coat of aviation gasket sealer on head gasket surface as a belt and suspenders approach. While I like stacking the odds in our favor I am worried this may have some negative impact - anyone want to weigh in? I don't recommend it.
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Personally, I'd go with the new bolts. They are to be stretch bolts and really you don't wanna run the risk of having to do it all over again.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
