Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
460 1990 fuel gauge problem
- Year and Model: 460 1990
- Has thanked: 0
- Been thanked: 0
Hi experts.. The misses got stranded because the fuel gauge was not yet on reserve (didn't start blinking) but fuel tank was dry all the same!
is there something i can do about it?
Can i reach the fuel gauge measure thingy eassily?
Best regards
Arnaud
Netherlands
Best regards
Arnaud
Netherlands
- billofdurham
- Year and Model: 855, 1995
- Has thanked: 0
- Been thanked: 3 times
Re: 460 1990 fuel gauge problem
A graphic description.fuel gauge measure thingy
It is easy to do:
You will see the unit is held in place by a large, knurled ring. This can be removed using a special tool or a large, adjustable wrench or a piece of wood tapped gently with a hammer.
When you have the unit out you can test it with an ohmmeter. Resistances are:
Full tank 35-40 ohms.
Half full 76-82 ohms.
Empty 276-290 ohms.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- Has thanked: 0
- Been thanked: 0
and then replace it?
it seems to work but keeps hanging just above reserve..
can the trouble also be in the dashboard?
- billofdurham
- Has thanked: 0
My first thought was a bulb out in the reserve light on the dash, but it isn't often used so, in theory, should have a long life. It could be dead.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Hi,
It is the needle for the gauge which doesn't go below the reserve(red) area..
- billofdurham
- Has thanked: 0
Sorry, I am used to reserve lights.
Fuel gauges do develop faults, but only rarely. Is the float arm on the sender unit going all the way down? They have been known to stick.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
That's something what can be fixed easily!
can one reach it from the outside?? (below the rear seats??)
- billofdurham
- Has thanked: 0
It is in the attachment in my first reply.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Ah, thanks.. i have to fiddle with my computer first to open it..
It will work out in time...
Temperature gauge and fuel gauge quit working simultaneously after valve job
by Uncle_Paul » Thu Jan 07, 2016 8:54 pm » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 10 Replies
- 3392 Views
Last post by 93Regina
Sat Jan 16, 2016 10:08 pm
- 3120 Views
Tue Mar 08, 2016 11:12 am
V70 front brakepad and rotor disc replacement -- cost $460
by Selvi » Thu Jun 23, 2016 12:32 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 4 Replies
- 487 Views
Last post by MadeInJapan
Fri Jun 24, 2016 1:55 am
- 3758 Views
Last post by difflock54
Tue Jun 28, 2016 7:45 pm
