My right front tire seems to wear more quickly than the others.
Does it have something to do with the torque,
or would it probably be a suspension issue?
Also:
I'm going to do an "X" rotation this week.
I notice the Columba rims are R/L specific.
If my tires are not directional, would it matter if I did a simple "X" rotation?
The tires are Michelin Primacys, which I believe are almost 2 years / 60K old.
850T - Does right front tire wear more quickly?
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
Unless your are spinning out or cornering at excessive speeds turning left(quite likely) it is an alignment issue. Any old rotation will work fine with the Columbia rims; purely cosmetic. I turn very hard left corners so I do wear my outside edge on my RF tire a bit more than my other tires.
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
Can a front left tire can wear out more quickly? = longer radius on the left turn, more left turns? BUT my opinion, if they would have been crossed front to rear, since installed the wear would have balanced out.
BTW.UPS yes big brown has been studying and practicing right turn tech-delivery systems..= less waiting time..
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
No. You need to have an alignment done. Mine did too, and it turned out to be a bent control arm that could not be properly aligned and was causing the car to pull left, and the right tire was wearing out more quickly because the alignment done on the car was done to compensate for that.
'98 S70 T5
2016 Chevy Cruze Premier
- 11 Replies
- 2516 Views
Last post by icrashcars
- 1353 Views
- 14 Replies
- 9902 Views
Last post by chitownV
- 13 Replies
- 1257 Views
Last post by foggydogg
- 1457 Views
Last post by oragex
