89 760 wagon/turbo
mtemart
Year and Model: 760t 1989
Post by mtemart »
Where is the AIR FLAP ACTUATOR SOLENOID VALVE located in my 89 760t wagon located?
thank you in advance
marty
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I can't find a listing for that.
Two things that come to mind are the idle speed air control valve, which is classed as a solenoid, located on the left side of the engine under the intake manifold and the air box thermostat which does control an air flap.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
mtemart
Post by mtemart »
This is what Auto Parts World calls "air flap actuator".
thanks
billofdurham
A heater part, not engine.
That looks like the air blend door solenoid which is on the bottom of the heater casing.
Bill.
Previously:
mtemart
Post by mtemart »
Is it possible that this is what's keeping my vent flaps from operating?
And, what might be the problem with the vacuum line that allows the heater control valve from opening? I have no pressure from the little port on the firewall that feeds the htr cont valve, altho, there is pressure on the little ports on both sides of it, again on the firewall, passenger side?
And, what exactly does that air blend thing do?
thanks
bojified
Year and Model: 2003 XC70, 2004 S80
Has thanked: 1 time
Been thanked: 2 times
Post by bojified »
You have ECU (Electronic Climate Control). That part takes signals from the ECU computer and opens and closes vacuum valves that in turn move the flaps through the use of vacuum diaphragms. You should normally have no vacuum at the hose that hooks to your heater water valve at the fire wall unless you have the "Recirc" button pressed or the system is asking form max cool. The system has a self diagnostic feature where the AC button will flash after the initial startup. There is a way to read the codes and I know there is a trouble shooting diagram in the Volvo service manual (greenbook) and I think as well as on the 700/900 FAQ available on this site and others. It is a very reliable but sophisticated system and just buying/replacing parts may not get to the bottom of the issue. Best to go through the trouble shooter. Good luck Scot
2004 S80 Wife's daily driver. Still have, 2003 XC70 T Daily Driver. Still have, 1997 854 Kept going for daughter, 1992 944 - Diplomat Delivery, 1997 855, 1989 744 saved my life!, 1987 744 T, 1988 780 BERTONE, 1988 765 T, 1987 744 T, 1981 244 DSL, 1974 164, 1976 265 PVR, 1981 264 GLE, 1971 145 DL, 1976 245 DL
mtemart
Post by mtemart »
Scot,
Thank you so very much. It is much needed info...
marti
billofdurham
bojified, welcome to Matthew's Volvo Site.
Bill.
Previously:
bojified
Has thanked: 1 time
Post by bojified »
Bill- Thank you- I have been lurking for years but felt I had info I needed to pass along....I enjoy reading your expert advice.
Scot
bojified
Has thanked: 1 time
Post by bojified »
Marty....here is the FAQ I was referring to:
http://www.brickboard.com/FAQ/700-900/H ... osticCodes
Scroll up and down as there is a ton of info there about the ECC. Should provide you with most of the info you need.
Scot
