How to remove a certain light bulb...
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
E170_Driver
Year and Model: bye V70 2.4T, 2001
Post by E170_Driver »
The light behind the driver's side temperature dial went out. How do I remove this unit from the console/dashboard in order to get to the bulb? Anything to worry about while going in?
Thanks much
Jan
Former 2001 V70 2.4T owner
Joe Hurless
Year and Model: e36 328is
Post by Joe Hurless »
The key to this is that little strip of moulding at the bottom with the little rubber tab on it. Use a pocket screwdriver to get into the sides and pry that little panel off of there. underneath will be a few screws to remove. Just go from there and you'll be all set.
There's not a lot to worry about here. Most parts clip in... removing them may make you feel like your going to break them. Just be firm and you'll be fine.
