You can vote for all 22 if you've experienced all of them, and you can change or add your votes over the months/years.
If you've had that problem, please "vote" on it. Please vote only on parts that have failed, meaning parts that have actually broken.
What is not part of this list would be consumables like struts, windshield wipers, tires, etc. Those are meant to wear out, and expected to be replaced.
List your 850/S70/V70/XC70 parts failures, 1992-2000 only
- Has thanked: 2856 times
- Been thanked: 1332 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
ABS module
ECC/blower/resistor
Head gasket
ETM
Spring seats
MAF
Air pump
ECC/blower/resistor
Head gasket
ETM
Spring seats
MAF
Air pump
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
-AWD Bevel Gear and associated mechanics (i.e drive shaft)
That's a big one for sure!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
Inoperable cruise(vacuum or switch related)
Environmentally friendly glues on certain models
centre rear taillights on sedan
Power antenna
Power antenna
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
jblackburn
Fuel pump/fuel pump relay
Cam sensor
Crankshaft sensor
What are we counting as "costly"?
Cam sensor
Crankshaft sensor
'98 S70 T5
Brewmaster
- Year and Model: 1997 850 Base(?)
Headlamp control switch
Air box thermostat (N/A models)
Your token displaced, slightly disgruntled Saab aficionado
1997 Volvo 850 Base (daily driver)
1987 Saab 900 SPG (hit-n-run'd, under reconstruction)
1998 Dodge Ram 1500 SLT 4x4 (SO's ride)
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Central locking
Keyless Entry
Window switches
Interior lights
Dash Dimmer
Radio Codes
A/M HU Wiring Adapters
B+ Cable
Charging system
Rear Hatch wiring failure
Rear Hatch Latch - Cold Weather
Rear Washer issues
T-Stat and Temp Sensor
+1 on Timing Belt !!!
Keyless Entry
Window switches
Interior lights
Dash Dimmer
Radio Codes
B+ Cable
Charging system
Rear Washer issues
MMMM what comes to mind immediately.......
sporadic Central locking ( keep a spare key)
stupidly priced keyless lock button, on my third
Window switches- burn out, one smoldered
light switches - crumpled in my hand
head lights
tail lights
B+ Cable
Charging system (new battery every other February, thats right 1@2years)
drafts from all the doors
windows constantly going on and off track
Incredible wind noise at highway speeds, good thing the radio (FM) is good
loose dashboard rattling , that no one could confirm until after 4 years, now $3,000 repair thats not happening
ETM (yesterday) software fix ( around 2006) put me 4 months out of the warrentee period $1200
Temp Sensor, randomly on/off -> ultimately new radiator-> which fell out of the car 350 miles from home. (2 years ago)
Timing Belt , got that done yesterday too (~$750)
front struts, third set now.
gas milage never better than 20-22 mpg
engine EMF interference on the AM radio that goes away when you lock/unlock the doors once or twice.
hot air that comes out all over the place no matter where you dial it to go.
some kind of sticky organic gue on most plastic surfaces that can only be peeled off
when clean, dashboard surface that reflects off the windshield on sunny days obstructing the drivers view
rear hatch interior panel that keeps falling off
stupid front wheel splash guards that get ripped off when backing up in snow.
corosion of the silver coating on the (mag) wheels
brake shoe life of ~20,000 miles, and squeeling when not worn
sticking brake calipers
I'll let some one else speak now............
head lights
tail lights
B+ Cable
- 1604 Views
Last post by foggydogg
- 36 Replies
- 7947 Views
Last post by bmdubya1198
- 18 Replies
- 8616 Views
Last post by rspi
- 1373 Views
Last post by clarkerussell
- 23 Replies
- 6220 Views
Last post by oragex
