IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2001 V70 2.4T bad ignition coil replacement...
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
regent
Year and Model: 2015 XC60 T5
Has thanked: 1 time
Been thanked: 5 times
United States of America
regent
Re: 2001 V70 2.4T bad ignition coil replacement...
Post by regent » Wed Sep 05, 2012 4:48 pm
Trimming the insulating boot may help prolong the coil's life if it has no internal failure. Cleanliness when handling and installing plugs and coils will also help prevent surface leaks and premature failure. These coils work under lots of stress due to heat; oil contamination is another 'insulation killer'. When I do plugs, I would vacuum the ports just before removing the plugs, and would also clean the coils' boots with some alcohol.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
ONV70XC
Year and Model: 1999 V70 XC
Has thanked: 0
Been thanked: 0
ONV70XC
Post by ONV70XC » Wed Sep 05, 2012 6:20 pm
Do you necessary see 'Check Engine' light when you feel coils need replacement?
precopster
Year and Model: Lots
Has thanked: 4 times
Been thanked: 108 times
Australia
precopster
Post by precopster » Thu Sep 06, 2012 4:24 am
The check engine light pointing you to the correct coil (by means of a coil number specific code) is usually the final phase in coil failure.
No point in suspecting them yet because you would need to buy a new one and swap it into each of the 5 positions then drive it some on each new position to be sure and that would just be a waste of time.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
GreekXC70
Year and Model: XC70,2001
Has thanked: 0
Been thanked: 0
GreekXC70
Post by GreekXC70 » Sun Sep 09, 2012 11:42 am
Thanks, great post even allowed someone who hates to work on cars like myself to fix the problem; and truly it wasn't that hard after I got the engine covers off. I'm not sure how much I saved, but I bet is was significant ... my wife was shocked I was able to fix it.
ez4u
Has thanked: 0
Been thanked: 0
ez4u
Post by ez4u » Wed Oct 17, 2012 9:27 am
Hey guys,
I have a 98S70 non turbo, I have a P0304 cylinder 4 misfire detected. When I tried to change the cylinder coil, mine are different. Plz see pic. So, now I don't know if I should change the spark plug wires or the main coil which delivers elect for all five cylinders. Any suggestions. Thanks.
precopster
Australia
precopster
Post by precopster » Wed Oct 17, 2012 4:03 pm
'98s have leads and a distributor cap and rotor button. Because the OBD system narrowed it down to cylinder misfire I would first check the corresponding spark plug first (to check for damage) and then pickup a set of leads. ONLY use Bougicord which are OEM. The other brands don't seem to work at all well.
ez4u
Has thanked: 0
Been thanked: 0
ez4u
Post by ez4u » Wed Oct 17, 2012 6:21 pm
Ironically, I changed the spark plugs about 5k miles ago, with NGK brand. They weren't the cheapest but priced mid range. So, I thought they should be ok. Bougicord ... Is this the park plug brand or the wire brand?
Thanks
precopster
Australia
precopster
Post by precopster » Wed Oct 17, 2012 6:27 pm
Volvo brand plugs are OEM. Bougicord is the brand of wire Volvo use.
precopster
Australia
precopster
Post by precopster » Sun Oct 21, 2012 3:17 am
My wife's 850; Goldie as we call her had a misfire over the weekend so I posted in the 850 forum about it : http://www.matthewsvolvosite.com/forums ... =1&t=52348
BobbyC777
Year and Model: V70 2.5T, 2004
Has thanked: 0
Been thanked: 0
BobbyC777
Post by BobbyC777 » Fri Dec 14, 2012 4:19 pm
Great writeup and pix!
The only thing I'd add pertains to the "turbo air delivery unit". My experience was that just removing the two T25 Torx fasteners was not enough to get the pipe to move at all. The pipe has a hose connector at either end. I loosened the 7mm fastener on the rear clamp and this allowed me to pull it out of the sleeve and raise the pipe enough to allow plenty of access to get the plastic covers off and gain access to coil packs and plugs. I didn't have to remove the front clamp but it sure looked like it would be tough to get to.
