abs and trac lights
panda
Year and Model: 1998
Post by panda »
How can i turn off the abs and trac warning lihhts on the dash.
thay are on constantly.
What in fact are they warning me of and what is needed to fix ?
thanks in advance
panda
Post by panda »
woops i see this has been addressed before. i will read past info.
I do not have a check engine light on however. Is this pertenent or a clue/
thanks
jjsull
Year and Model: 2000 V70 XC
Post by jjsull »
Possibly a faulty ABS. There are a number of posts on ABS options including,
repair, repair with rebuilt, replace with OEM. If you are at all handy you can even repair yourself from info on this link.
https://www.matthewsvolvosite.com/forums ... ule+master
ONLY AFTER making sure that's were the fault lies.
Good luck
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Either you have a loose or dirty ABS sensor or you need to rebuild the ABS module. Most likely it's the module since all 1996+ modules go bad eventually.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
panda
Post by panda »
Thank You!!!!!!!
BEJinFbk
Post by BEJinFbk »
What can I say... He has a great site!
Thanks, Mr. Rocha! :mrgreen:
