99 S80 spark plug firing order
swoff57
Year and Model: 99S80 t6
Post by swoff57 »
I need the spark plug firing order for 99 S80.
I was coded misfire on 4th cylinder.
How do I find out which is the 4th cylinder?
537playing
Year and Model: 2005 S60
Has thanked: 1 time
Been thanked: 5 times
Post by 537playing »
Simple. Straight six engine is numbered one thru six starting at the timing belt or the passenger side of engine.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Look for any obvious cracking in the plastic on the ignition coil for that cylinder. And the condition of the spark plug itself of course :wink:
'98 S70 T5
2016 Chevy Cruze Premier
ovlov76
Year and Model: S80 2000
Post by ovlov76 »
For what it's worth, the answer to the question of what is the firing order, the answer is 1-5-3-6-2-4. As far as I am aware that is it for all straight 6 engines (not necessarily V6's). And yes number one is located at the timing belt, or the front, or even the RH side of the engine bay. Not all passengers are placed on the RH side......
markyoung
Year and Model: 2004 Volvo V40
Post by markyoung »
537playing wrote:Simple. Straight six engine is numbered one thru six starting at the timing belt or the passenger side of engine.
Is this also applicable with my old 2007 Volvo S80 Spark Plug? Sorry for this silly question but im just a newbie when it comes to some technical terms and technical stuffs.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The new engine family 6 cylinder in a 2007 s80 has the same firing order and cylinder numbering.
