P0011 Engine Code - camshaft sensor - timing advance
I've got this code intermittently the last 3 months. Has anyone had this. Doesn't seem to affect engine performance. And the cure? replace sensor. mechanic has told me that mechanic forum says contaminated oil could be the culprit here.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Hello, How many miles are on your car? Kira
JDS60R
- Been thanked: 3 times
A friend is dealing with this same issue. We pulled the solenoid and found some sludge in one of the oil galleys. Clenaed it and replaced it with the new gasket which has a filter in. His is an 02 S60 N/A. The code is now very infrequent. The engine light comes on and then goes off. We will clean the solenoid next time and if not a complete fix we will replace the VVT solenoid.
Wish I had an answer for you but this is where we are at right now.
Retired
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Here's a bit of reading for you:
https://www.matthewsvolvosite.com/forums ... =1&t=21162
https://www.matthewsvolvosite.com/forums ... 3&p=117648
And finally, the replacement procedure:
The solenoid replacement should be almost, if not exactly identical on your S60 as ecb's XC70 if you choose to go about it yourself.
'98 S70 T5
2016 Chevy Cruze Premier
- 3068 Views
Last post by jbkeene
- 896 Views
Last post by jmartin919
- 1979 Views
Last post by FLXC90
- 16 Replies
- 12036 Views
Last post by Austingrayy
- 3950 Views
Last post by oragex
