S60 position bulb failure /service light
position bulb failure fault is up on the left hand display on the dash,all bulbs are ok-i have tried to delete this fault with a scanner but it wont delete-could anyone have any advise, also the service light has came up ,is there any way i can reset this to remove it ,,thanks
billr99
- Year and Model: 2002 V70XC
Make sure you check the taillights closely. There are two bulbs in there that sometimes are hard to see that there are indeed two thanks to there locations in the housing and the optics of the lens. Perhaps one of those is out.mykemac wrote:position bulb failure fault is up on the left hand display on the dash,all bulbs are ok-i have tried to delete this fault with a scanner but it wont delete-could anyone have any advise, also the service light has came up ,is there any way i can reset this to remove it ,,thanks
Cheers,
Bill
'05 XC70 (Lava Sand)-235K kms to-date
'02 V70XC (Ash Gray)-375K kms to-date
And a whole tonne of other Euro stuff (Volvo (8), VW (6), MB (1), Audi (3), BMW (2), SAAB (5), Land Rover (4), Porsche (2), Opel (1), MG (1), Mini (2), Sunbeam (1))
thanks Bill for your prompt reply I will look for them and hopefully that annoying fault code will go,any ideas about deleteing serv light,i can remember someone posting something about"keeping buttons pressed on the dash for a few seconds in sequence or something,if someone has any ideas they might let me know thanks
billr99
Only way I know to clear codes and in turn lights is with a OBD2 scanner or VADIS/VIDA. No more DIY in that respect thanks to all the ECUs being used now. Sorry.
Bill
Bill
Joe Hurless
- Year and Model: e36 328is
You have a tail light out (67 bulb), your position light warning will go away when it is replaced. If replacing one doesn't work, replace them all.
Another thing to check is your headlights. Volvos are weird about headlights. If they are differnet brands this will often cause a bulb failure light. For example, if you have 2 H7s in there, one Sylvania and one Wagner, this will often trip the failure warning. Make sure both bulbs are the same.
To reset the service light, turn the key to position 1 (where just the red airbag light comes on), push and hold the reset button on the instrument cluster, while holding the button down turn the key to the on position (when all the lights in the instrument cluster come on) and wait about 10 seconds. You will see either the service light or the yellow triangle light blink a couple of times. When it blinks, let up on the button and quickly push it again. This will reset the light.
- 4904 Views
Last post by Oly850
- 4140 Views
Last post by silentcircuit
- 24710 Views
Last post by JNavas
- 5069 Views
Last post by JRL
- 21 Replies
- 12111 Views
Last post by Georgeandkira
