S70 Engine number
Post by 0230683 »
I need to buy a timing belt kit for my S70 turbo 5254T. I cannot read the complete engine number from the ink sticker on the timing belt cover. Surely this number appears elswhere. Where can I look?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
'98 S70 T5
2016 Chevy Cruze Premier
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
YEAR and VIN
0230683
Post by 0230683 »
jablackburn wrote:Image
Thanks so much
turn7
Post by turn7 »
I have 2000 S70 N/A. The number in the location indicated in the picture above reads 9186836 which is obviously much higher than the 1266128. However, it is so far above that it makes me wonder if it's proper. Are the numbers not incremental and some sort of date code?
The tag inside the drivers door indicates that the mfg date is 10/99.
Thanks for any insight.
jblackburn
You can also look on top of the timing belt cover. If you're looking for a timing belt/tensioner for your 2000 though I can go ahead and tell you, it is 100% the mechanical tensioner.
'98 S70 T5
JRL
Post by JRL »
2000s are all the same
